Transmission help
bell_man
95 gmc yukon. The trans won't shift into second without letting off gas and I have no overdrive. I want to make sure this is not a PCM signal sending issue before I pull the trans and have it rebuilt. So my question is how do I tell if my PCM is sending the shift signal to the trans? Is there a method with a volt/ohm meter?
Sounds to me like the Throttle Position Sensor is going out to me. I would definitely check that before pulling the tranny.
