No its not I can't believe this I've never heard such bad subs. Actually I can barely hear them.. ridiculous..
Anyway dropped trans off today should have it end of next week
sent from my truck in a field
Dropped the Subs off at ups store and picked up my trans should be going in this weekend
Upgraded hd shift kit clutches billet servos and internals new stock stall torque convertor
Upgraded hd shift kit clutches billet servos and internals new stock stall torque convertor sent from my truck in a field
Damn, you should have gotten a 3k stall. At least you would have it for if/when you do a cam upgrade, which you should; What subs are you going to get next?
No its not I can't believe this I've never heard such bad subs. Actually I can barely hear them.. ridiculous..Anyway dropped trans off today should have it end of next weeksent from my truck in a field
i am running a tw3 10 in my truck and it sounded really quiet untill the suspension broke in and now it is pretty loud. They are a bit prucey butbtheybsound great. They are a dvc speaker sonyounhave to make sure your amp can take a 1 ohm load or you can wire them to 4 ohm.
I'm keeping my 12s and looking for bucket seats to put in the back. I didn't order a higher stall convertor because my budget was only 1200
Transfer case upgrade, everything looked good in there no wear or shavings Thank god.
Starting trans swap now
I've seen that last pic all too much on my truck lol
Sent while drinkin' a cold one...
Edited by rdnckhntr94
yea thats what the first few pics were the last one of the tcase was the pump upgrade installed
Drove it today and it's shifts are on point and perfect even jumps a little way better than it ever was hoping it stays that way.
Of course I say this and nothing but a couple weeks later and my trans. goes out again. Must be Karma...
To big of tires being run on an under modified trans? That's what mine did... plus whoever had it before me (before 85,000 miles) had work done on it..
But I just put money down on a 42" led light bar can't wait to get it
I had it upgraded but the pump or something went out. The temp stayed normal but it just wouldn't build pressure to go anywhere. Sucks
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,305 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
