Yes mine are.
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
Power extend/retract but not fold
Mine are just power glass, heated, signal. Google them. Kool Vue GM73EL-S and GM73ER-S those are the numbers for each side separate. That's how I got mine. A little under $300 for the set
Yea that is a good price I used to build regular mirrors for ford and a power fold heated tinted glass without blinker was 350 for one mirror
Sent from your truck via Tapatalk
The driver side isn't the one that gets me when someone is being an ****. I'm usually blinded from the passenger mirror
I'm just wondering its all plug n go? Being a half ton I didn't think it had the wiring harness to make the mirrors go out
Yes it is plug and play not "plug and pray" I did this.
Remove door panels, unplug mirror from window switch, unbolt mirror and remove.
Bolt on new mirror, plug in, replace door panel, have a beer and admire your work.
Takes 30 mins including time to admire and have that beer
They are manual extension.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
