Gearing for 37's?
  • Replies 37
I think I will probably go with the 4.56's just so I can get a little bit of power back, hopefully get better mpg's around town, and at 80 mph on 37's it will sit right at 2500 rpm's
exactly, 4:56 gives you the best of both worlds i think...
4.88's........ you have a 60E and a 5.3. It needs more help than less. Revving to the moon......... Lol. When you have .7:1 overdrive with that big of a tire it will not. With the convertor locked 4.88's comes out to 2482 ( or 2500 rpm) at 80 mph. I run 30" tires with 4.10's and am about 300 rpm higher rpm at 80 mph..... and get your mileage with a loaded to around 7500 lbs 1500HD with an LQ4 and 4L80E.
You will be better off with 4.88's...... don't fear gear reduction lol.
Agreed. The difference between 4.56 and 4.88 is minimal when it comes to rpms. Why spend the money to undergear? Any chart will place you at 4.56 for 35s based on tire height alone. Then you need to factor in the weight of your tires, the weight of the wheels, and the overall rolling resistance of the lifted truck. If you tow that's another consideration. Poke around on GMFS. There's a lot of gearing knowledge there and guys who actually have geared trucks. Seek out experienced advice on the matter.
Its only a 200 rpm difference at 80 mph. Which will give me better fuel economy around town? That's the one I'll go with then haha
Exactly...... it's only 200 rpm. The one that works the truck the least in a stop and go situation will net the best mileage....... which would be the 4.88's. If you want mileage put it back to stock, lol.
It would probably cost more to put it back to stock than it would to switch the gears haha... I guess 4.88's will make the cut then.
Im guessing 2500 rpm's is optimum for about 80 mph? That's what I'm collecting from this...
Depends on the vehicle. Something aerodynamic, low to the ground and overall more efficient would benefit from less rpm. But your truck is absolutely none of that, no offense, neither are mine even sitting stock. You have low cruising rpm now with your 3.73's at 80 mph and those tires...... and look at the mileage you get lol.
People will argue with you all day long on optimum rpm for mileage...... which is great for stock stuff with aerodynamic consideration. I doubt your highway mileage will increase from what you get now...... but it won't go down either. That's why I always say leave it stock if you want mileage because this whole lifted big heavy tire mileage talk is absolutely a joke.
You will have power you thought not possible with the 37's with 4.88's.... and a reasonable cruise rpm lower than a lot of stock combo trucks. I mean I am over 2700 rpm at 80 mph with either or my two trucks rocking 245/75R16's and 4.10's..... but the 80E's overdrive is only .75:1 as well. Leave it at that.
I was just sayin from experience a truck I owned before had 4:88's and it was too much I thought...I always wished I had 4:10's or 4:56's instead. I know it's only couple Hun rpm but hey, my old 1500hd the difference between 1900 rpm and 2100 rpm was a couple mpg almost...
I get what nota member is sayin too. Lifts/trucks and MPG don't go together. If you run bigger tires say good bye to ur fuel mileage doesn't matter what you do. You are driving a land yacht...I've never complained about fuel economy with a truck, it is what it is...
Different trans, different ratios in said trans and I don't know what you had for tires nor does it matter. He has a deeper overdrive than the 80E does so it lets you run a little more gear while keeping the revs down slightly. Like I said it's all moot in the end worrying about fuel economy lol. I get maybe 12-13 mpg in either of mine and honestly couldn't possibly care less.
This is all but confusing lol, not to high-jack the thread but I was wanting 4.56 gears but I am not increasing tire height but rather width, to hopefully 305's so I am not sure of what route I should go with it either.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
