"01 8.1l Cam Sensor substitute?
mamachala
My cam position sensor is failing,code P0342, and GM discontinued a replacement for it. There are no aftermarket ones available either. Do you know of a workable substitute? I have read of people using one for an '02, will that work? In case you need it , the last 8 of the VIN are 1F122827.
HELP!
Jack
Advance lists the part but when they try to order it is unavailable. Believe me I have tried all aftermarket suppliers. GM has left us SOL.
I looked at an aftermarket sensor for an '02 and physically it looks the same, but I don't know about functionally. These take an analog voltage in and put out a digital signal so I don't know if the electronics inside are the same. They are not just a switch. Maybe a Tech could help.
Jack
Damn....let me recheck it. Yep, let's do some more searching....
There's 1 listed on eBay right now....I'd get on it if I were you.
http://www.ebay.com/itm/ACDelco-213-1063-Cam-Position-Sensor-/130885635496?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e79644da8&vxp=mtr
Also take a look at GM 12572656....several on eBay and cheaper. This number was uncovered here:
http://www.nc4x4.com/forum/index.php?threads/need-help-finding-camshaft-sensor-for-8-1.135213/
Little more info for you:
http://www.oehq.com/oeparts_12572656.htm
Thanks bossier, I was just calling around the country from a list my dealer printed out but nobody had it even their inventory said they did. Never thought about ebay, I just bought the one you found.
By the way , one of the parts guys I was just talking to said you could use an '02 sensor if you used an '02 cam gear also. That's alot of trouble. Evidently the'02 might stick into the engine a little further, might be able to shim it if you measure it accurately with calipers. Just some info for the next guy seaching on this thread.
Jack
There were several listed by the GM part number that i posted in the last reply....it's supposed to be the correct one as well.
