Doubling up leveling kits?
I have none because I have an older 2wd with coils, and out Dodge has a level but also has a sold front axle
As stated, just don't go over 2.5" total. If you only have 2" on top, then yes, you can add an additional .5" on bottom. And just fyi....the actual spacer will only be half the height of the lift desired. For example, the spacer for a 2" kit will only be 1" tall....but the desired lift height is achieved because of the suspension geometry. You could also try the fender mod mentioned above. Usually, 285's fit with a leveling kit without any problems at all. What are the specs on your new rims?
im not sure on the specs of the new wheels when i ordered them from the shop i said stock width and offset but theyre obvioiusly not, they stick out wider than stock not much but theyre deff not stock specs
