Need help with master window control
My 07 NBS 2500HD's master window switch is having problems raising and lowering the rear windows (front work fine) the rear windows work fine from their own control. While I suspect that I will have to pony up for a replacement switch ($$$) I have not figured how to get into the arm rest to even look at the switch module. So has anyone figured out how to get in there??? and has anybody ever be able to repair the module??
TIA
Randy
I think you're going to have to pull the door panel to gain access. My friends 2008 had a similar issue and he had to get a switch panel.
  • 2 months later...
