2014 1500 Payload Numbers
Check out the new payload numbers for the 2014 1500 trucks @ http://media.gm.com/content/media/us/en/chevrolet/vehicles/silverado/2014.tab1.html . Unless I'm misreading it, the "standard" 1500 4wd 5.3 crew cab (near bottom of page) will have a payload rating of 1957 lbs (vs ~1650 now). That's big news for folks that tow, and are bumping up against the rated payload numbers. What's interesting, is that the "max tow" 1500 4wd 5.3 has a ~100 lb lower rating.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
