Chris' 04 Sierra 1500 Fun Daily Build
Chris
  • Replies 699
Chris, you don't have the tie down rings at the bottom of each corner??
They are there
  • 1 month later...
Here is what i am hoping to bring my freshly paid off to next year
Bedsides are $400 each from LMC. At some point i want to do the Denali front end. Also have to find the right drop. I dont think 2/4 is enough and i know a 4/6 is too much. Cant find a 3/5.
So I have decided on my next wheels and tires when the tread on my Goodyears is done. I will go with a 22" rep of the 2014 SLT 20" wheel. But they will be in a matte black. The tires will be a Nitto NT555 in a 285/35ZR22. Being on a small fixed income right now, not much of anything will be going on with the truck. it kind of just sits in the garage right now and gets driven 2-3 times a week.
  • 4 weeks later...
Decided on a DJM lower control arm drop in the 4/6 variety. Also the rear will be notched and flipped. Right now my wheel wells measure 35.5/37.5. Supposedly will be 29/30 after drop. And ill run a 30" tire. Not sure how that will work out but an experienced installer and dealer told me it woll all work right. So time for me to find some 17" take-offs to run after i do it. Til i figure it all out. I have a 3/5 option as well. I already am planning to buy the rear shackle from the 3/5 to bring the rear up if needed. The DJM keeps the frnt suspension geometry the same as stock and uses stock springs and spindles. I will most likely get new Moog springs. I also have to replace the rear springs
  • 4 weeks later...
I really enjoyed reading this whole thread, Chris!
Thanks for taking the time over the years to put it together.
Your truck and mine started from close to the same place and I will be doing many of the changes you have detailed here.
I swapped my 4.8 for a junkyard 5.3 a few years ago out of necessity... but a rebuilt / tuned 6.0 is on the horizon. Either a LQ4 or LQ9, whatever I can find locally for the right money.
Gonna rebuild the rear end and trans prior to that though.
I love the SS wheels and gauges too! (Are those OE or repro's?)
I know a lot of the stuff you have done was due to the need to tow a heavy trailer (which I never do) so I wouldn't need to do 2500 rear leafs and stuff like that.
Either way, Props on doing what you've done so far, as time and money allows.
Cheers!!
:cheers:
Wheels are repro, gauges are an OEM 2500 cluster with actual GM SS face, and then a repro escalade bezel
Cheers!!
:cheers:
Also the HD suspension is coming off. Trying to find a drop i like with some 22" SLT Repros.
Ok, I assume 2500 gauges because it added trans temp?
Yes. Any 1500 with a 6.0 comes with it, but ones from an HD with 6.0 are easier to find
Got some questions for you. Where did you find a 2.5" level? All I can find is 1.5"... how did the lift,265s, exhaust, and cai effect mileage before the 6.0? Trivial question, just curious.
265's came first. My level may be 2". Who knows. I probably lost 1-2 MPG going from HT 255/70 to a AT 265/75 on the highway. Basically everything done before 20's i was getting 13/18. As it sits now I am at 14/18.
And depending how long you can wait, my level, Bilstein 5100's, and rear springs may be available come summer.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
