Chris' 04 Sierra 1500 Fun Daily Build
Chris
Still no hydroboost? I mean I did do that amazing how to since you asked me for one lol
Sent while drinkin' a cold one...
  • Replies 699
I collected parts for it, but other priorities took over. I moved out on my own which meant down sizing my parts stash and my budget because I have more bills now
I picked up a trim panel at the dealer. Wasnt bad in price. Cost me $34. Did an antenna delete. I dont listen to FM radio and havent since I owned the truck so I didnt care to do a relocation in the fender
  • 1 month later...
The build will be brought back soon. June 1st im going to order a Grant steering wheel that retains the controls because it just looks good. Then im going to start collecting parts to upgrade the brakes
What's this steering wheel look like? You have me intrigued now that I'm a GMT800 man again.
Sent from my Droid Ultra
Here it is
Airbag not included, neithef are the buttons. You reuse the ones you have now
The air bag saved me from eating dashboard quite a few years back
How hard is it to swap out the Steering wheel Chris?
Depends swapping a base for base or loaded for loaded is fairly quick. Swapping a base for laoded whicj I did takes a while because you have to change the harness
I'd be swapping a loaded for loaded. Air bag complicate things much?
Nah. 2 small allen wrenches or jewlers/small computer screw drivers in the holes on the back of the wheel pop the air bag free. Make sure you disconnect battery and let sit for like 30 mins to de-energize
  • 3 weeks later...
New wheel is in. Hoping to install on Sunday
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
