Cold Start Knock
jbutton1462
Hello. I have a 2003 Silverado 4WD Z71 5.3l with 156xxx miles. A couple months ago I noticed a "knock" on cold starts. At the time I was also losing coolant and had a block test performed and it showed that there was no combustion gases in the coolant, so I think the knock and coolant loss are unrelated. Mechanic could not find any coolant leaks and suggested I replace the reservoir cap. But I still have this horrible knock on cold starts. I have noticed that it goes away almost completely after an oil change, but it comes back within a few weeks and gets worse. Right now the noise will last a few minutes until it warms up and goes away. Sounds like lifter noise or rod knock. I am aware of the issues of piston slap and that GM says its "normal", but I have never heard piston slap before and want to make sure it's not something more serious. Can anyone help me out with this? It's annoying and embarrassing!
Should have been around here 10+ years ago. That was a big complaint for the 4.8L/5.3L was piston slap and CSK. Every 5.3L I've owned (several) and one of the 4.8L I had for work would have it when starting the engine up in the morning and then go away after a few min. Somtimes going to synthetic oil helped. It is normal and there are millions of these blocks on the road today with high milliage that continue to run just fine with it. Not to worry.
What octane are you running? For a while I tried running 87 and my engine didn't like it at all, but now I'm back to 89 and sometimes 91 and it runs a lot better, especially at start up.
And please give us details about your engine oil.
Try using a few tank fulls of either 89 or even 91. And does your specific engine call for 5w-30?
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
