Bluetooth UPDATE Ver.1.4??
Hope so because my trucks blue tooth sucks... I have to yell for anyone to hear me.
Not to get off topic here, but there is a GM TSB for that concern "gnet158".
GM has a new design microphone for low reception, low volume talkers, exterior noise, etc. I've actually had mine replaced in my 2012 under warranty. I wish I had a copy of the TSB #, but it appears I threw it away after my truck was fixed.... :happysad:
I've been lucky apparently. 09', 11', and now a 13' and everyone says the BT audio sounds fine. Even better than when using just the phone by itself.
Hmmm, come to think of it, I had the same phone for all 3 trucks. Just got a new phone yesterday, will report if anyone says the difference is noticeable.
  • 1 month later...
Any update on this? My Bluetooth shows I'm connected on the phone, truck does its thing on the dash, yet it won't work 50% of the time. My phone is a Droid Bionic. I had these problems on Gingerbread and Jelly Bean.
Talked to a few people now on the new phone (who have usable opinions, lol) and they said it sounds ok to them. This is a GS4 phone. Did the talking with the windows up on rural highways @ 55 mph.
If it helps, I usually keep the phone in the center console pocket in front of the climate controls or on the flip down console.
Ive yet to have one android that would connect and stay connected to my 2011, dealer always tells me its the phone grrrrrr. galaxy s3 and a new htc should connect
I was just around some family members with S3's, I could have checked to see how theirs did. I won't be back over their way for a month or more now though.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
