Great CC phone app
wurgs
I just wanted to tell everyone about a concealed carry phone app I found yesterday. Its called CCW Concealed Carry 50 State made by Workman Consulting. It has a interactive map that when you put in your permit it will tell you which states have reciprocity. It also tells you some details on all states laws by just picking that state from the list and has links to the states AG, State police and state statutes about that states CC laws.It seems to update info pretty frequently. It would be a big help to anyone who travels out of state to help make sure they stay legal. They do charge but at $1.99 its definately worth it.
Are you talking about the website or an app? Those living in border cities will find the app really handy. In 4 clicks I can have that states laws right in front of me instead of having to navigate a website.
It's a website. And before I travel I memorize any special laws of states I visit. For the most part its simple- you just need to know off limits places, if its a must inform state and if the no gun signs have any weight. If memorization isn't your thing the site has all state laws summarized in PDF format so you can print it or email it to your phone. I also know the owner of the site regularly checks to make sure info is current. I don't know anything about the publisher of this app so who knows if they do the same.
They are pretty good about updates also. The last one was 6/03 and had about 10 updates. I looked at the Handgunlaw website and it does look pretty good. The app is just maybe a little handier way to check laws. People might forget laws or the paper they print out but not many can live without their phones.
Sounds like Illinois is finally getting a CC law on the books. Read it passed the house and senate and awaits governors signature. The article didn't have the bills details but its a good first step.
  • 3 weeks later...
There have been 2 more updates to this app about law changes around the country including the new Illinois CC permit info. They really keep up with the changes and put out a quality app.
