35s on 4.10s?
tyhuck
OK, first let me say if this is the wrong section, I appologise. Its hard for me to decide where to put my topics sometimes.
I have been bitten by the bug again, so I am starting my research now, for a project that might take place a year or so from now. Now, let me begin by saying, I have read all of the other posts about regearing for 35s, and that 4.56 gears will give me more power and are better matched for 35s, and blah blah blah. My question is somewhat related, but a little different than all those topics discussed before (at least the ones I could find). My current truck has factory 4.10s, and gets about 13-14mpg on 285s. My last truck had 3.42s in it and still could pull those numbers on 35s. So, I am thinking that 35s will give me the ability to run a little lower RPM and possibly get a little more mileage out of her. Surely the MPG on 4.10s and 35s would be better than the mileage on 3.42s and 35s, right?
That being said, here is my question.
What is a realistic MPG number that I can expect out of my truck with 4.10 gears and 35" tires?
I know some guys have run 4.10s with 35s, so Im primarily looking for someone with personal experience here. Let me reinforce the fact that my truck already has 4.10s, and I CANT AFFORD TO REGEAR, so dont even start with the 4.56 stuff.
I still have 3.73's on 35's and I just keep my truck out of OD and I get 13.5 mpg (around town) so you should be seeing a bit better than that. Probably 14-14.5 around town cause you can still use OD. Its hard for my truck to move while in OD
Well, most of my driving is highway driving on rolling hills, so thats what Im most concerned with. With the 285s I can set my cruise at 70 and there are only a couple hills that will cause my truck to downshift out of OD.
It would surprise me if you see any better mileage... Specifically on the highway. If you're downshifting on inclines now, it will be worse with 35s. For example my mileage went down when I went from 35s to 37s with my 4.88s. I dont agree with the gearing charts but im "properly" geared for 37s yet i saw a mileage decrease. So, I'm running a little less rpm, but the weight and rolling resistance brought me down. I'd stick with 33s if you want he best balance.
Well, as long as it doesnt make it worse. Im just really disappointed that Im not getting any better mileage out of this truck now. I was concistantly getting 14.5 with my 05 that had 3.42 gears, a total of 5" of lift, 35" mud tires, and about 600lbs of extra accessory weight. This truck is 4.10 geared, only on 33" all-terrain tires, and the only extra weight is the camper shell, and Im still only getting 13mpg. That just doesnt make sense to me.
My train of thought was that 35s on this truck would have to give me better MPG than 35s on the 3.42s, right?
Dont get me wrong, I love the look of these trucks on 35s, but I dont want totally kill what mileage im getting now. I guess a trial would be in order. Would it be ok to run different size tires as long as I dont use my 4wd? I ask because I can probably fit a 35 in the rear of my truck now, and that would give me an idea of the MPG and performance I would expect running the 35s permanently.
Is this truck a 6.0? I'm sure you could run 35s on just the rear but you would still be pushing less weight up front since the 35's weigh more. Regardless, you will be undergeared for 35s and I just can't see you getting better mileage.
No, its just a 5.3. I wish it was a 6.0, then I could justify the crappy mileage.
So much for my theory. I had a 6.0 with 4.10s and the mileage sucked.
Yeah, I had a 6.0 with 3.73s on stock tires, and the mileage sucked too.
I guess I will just give it a try. Its not like im not gonna try it anyway. like I said, Ive been bitten by the bug. I dont know why Im so upset. I havent had a truck that gets over 14 mpg in over 7 years. I guess its just the thought of a stock half ton getting only 13mpg.
6.2 it !
6.2L are kinda pricey, at least the ones I have seen. Get the cheaper 6.0 and do some performance upgrades to it to make the same power as a 6.2L, but for almost half the cost. But I'm also stuck with my 02, and comparing prices between a used LQ9 and used 6.2L (whatever the production code for those are)
And Blackout, your truck looks rediculously tall in your sig pic. I wish mine looked like it was that tall haha
13 mpg is ok for a 1/2 ton v8 4x4, town and freeway driving.
16 mpg for freeway, long trip.
You loose 1 mpg for 33 to 35 tire size, 1/2 mpg for a lift.
My 1992 Gmc z-71 350 5-speed got the same mpg, as my 1999 silverado, listed below.
FWIW my 06 1500hd on 33x13.5's, 6.0 and 3:73's got 11-12mpg mixed. Highway was like 13-14 if I drove like 60-65mph anything more it sucked it back towing anything more than 2500lbs it got 8-9 and city was like 10 mpg. That was with a very well built 91 octane tune, CAI, full exhaust and port polished heads.
13-14 MPG with 33's and 4:10's is nothing to complain about man...
    TopBo
    TopBo
  • Who's Online   0 Members, 0 Anonymous, 1,234 Guests (See full list)
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
