New Wheels and Tires
Stevens08
I think you'll be fine. Although I suggest not lifting the rear. Defeats the purpose of leveling to get rid of, IMO, that horrid looking rake.
  • Replies 33
Blackout,
I understand how you might think the rake is ugly, but It still serves a purpose for me, as I occasionally tow heavy loads. I may consider not putting the 2" on in the back if it looks good enough for me.. But we shall see..
Looking forward to the pics! Also, you have the option of replacing the factory 1.25" block with your new 2.5" block, for only 1.25" additional lift in the rear. That will let you keep some rake, but not all of it. That's what I did with my 2" kit. Just an idea.
Thats my plan. However ive run into some issues installing my kit...The uper strut spacer went fine, the lower strut spacer however, the bolts installedwith the nut side up, rub on the front axle. The instructions show that I should do it with the nut side facing down, but this is virtually impossible without removing the front axle as the hole for the bolt is directly below.. any advice from previous installs???
On my '07 the rough country 2" spacer went in with nuts up. It was a 20 min super easy install on my truck with the lower strut spacer. I don't recall fighting the CV shafts at all.
what leveling kit did you get? I did the ready lift with the upper and lower spacers and didn't run into this problem. Maybe put the nut on the bottom instead. Don't think it will hurt anything to do it that way.
No, its the 2.5" lift from rough country. Comes with a .5" spacer on top of the strut. Then the typical 1-1/4 forged spacer block under the strut. The bolt runs through the lower control arm, through the 1-1/4" spacer and into the strut. then the nut goes on top of that. There is clearance at first. but then after torquing everything to spec, the nut just barely rubs the cv shaft. I can take more photos later this evening, im at work right now.
EDIT*** @ Cobrajet - I would like to flip the bolts, but the cv shaft is directly over the bolt location on the lower control arm/strut. Im not sure how i could install the bolt the other way without removing the cv shaft.
Dirtfan, please pardon me, but I have no idea what any of that is that you are talking about. However, i did resolve my issue. I just completely disassembled the upper ball joint which allowed more movement in the hub assembly allowing me to move the cv shaft out of the way enough to drop in the bolts. Fairly easy once i figured it all out. Wheels arrived today, I will put them on and take some photos tonight or maybe tomorrow after I wash'n-wax it :-D
ef0f4671-21c0-4578-a757-f655009f647b_zpsno liftde5a2de4-f23e-4f52-998a-3c25c85311fd_zps <- After The Lift
After the wheels and tires
Thanks! They fit great. I was nervous at first when I saw how wide they
were. I figured they would rub for sure. Thankfully they didn't. At the
tightest, they have maybe 3/4" - 1" of clearance. I was very surprised. I
think its because they are about the same diameter as my stock tires,
just wider. Did some minor offroading already. (more like basic trial
driving) Love the tires. Thanks for all the help.
    tonyb2760
    tonyb2760
  • Who's Online   6 Members, 0 Anonymous, 424 Guests (See full list)
