Unlock 2010 Navigation Unit
Just bought the wife a used 2010 suburban, and it came with the factory NAV unit. Going to install the Advent OGM1 in it for better functionality and would like to unlock the stock NAV unit so I can sell it on eBay or something.
Some things I know:
1. The suburban is an LT and did not originally come with NAV, the previous owner had it installed at a local dealership.
2. The factory NAV is a 2010-2011 version, not the newer 2012 version.
3. The suburban does have the BOSE speakers but not centerpoint.
Is this even possible? Is there a way to unlock the stock NAV to sell it or am I screwed without taking it to a dealer?
Not screwed. First I would just sell it as is and let the buyer take their vehicle to a dealer to unlock it after they install it. Another option is to search for unlock services on eBay or the web. Not too expensive but that may be a cost you will not recover when you sell the radio.
Myself, I have discovered a way to unlock them without taking it to someone with a tech2 or at least the 2003 - 2007 ones. I haven't played with a newer one yet.
As Rusty503 says, don't even worry about - the buyer can get it unlocked for the vehicle they install it in...
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
