Bug Deflector: Chrome or Smoke on White Diamond?
Hi,
I was thinking of changing my current bug deflector from smoke to chrome. Would this be too much chrome on the White Diamond with the chrome package? Don't want it to look "cheesy".
cheers Primo.
Got to have it! In our climate in Canada, there is way too much salt and sand on the roads in during the winter time. Front gets too many chips!
I put the smoke on my summit white and it looked terrible IMO... I took it off. Chrome is too cheesy, if anything get it painted to match the truck.
Chrome is cheesy. Paint to match or clear.
Sent from my DROID RAZR using Xparent Green Tapatalk 2
I own a '12 Sierra with the White Diamond color. I had 3m Paint protection film put on. Has been on for a year now and works great. You can faintly see it but looks 110% better than a bug deflector.
Did the same....seems to be holding up fine. Not wild about the look of the deflectors, but if you have to I would go with the painted to match.
Do this if you have to. Bug shields are ugly but if you have to have one, for the love of God, don't do chrome.
I agree shields are not attractive at all.. I live in south MS and even with all the bugs I hit, I just keep the hood clean. Had a stainless bugdeflector on my previous 99' - didn't look bad at all but man did it make a buncha noise!
    Frank V
    Frank V
  • Who's Online   4 Members, 0 Anonymous, 1,193 Guests (See full list)
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
