Pandora
Have tried this several times and based on my experience as well as the manal:
The ONLY way you can listen to Pandora via the Pandora App Button on the Dash Display is to connect your iPhone via USB cable. If you have an Android phone, you can use the App on the Dash Display to listen via Bluetooth.
All of that said, you absolutely CAN still listen to and see the songs, etc from the Pandora app on the iPhone via Bluetooth. Again the difference here is that to listen to Pandora songs wirelessly from Pandora, you must select the Pandora App from the PHONE and have media selected on the MyLink (Dash Display). If you simply try and select the Pandora app from the MyLink button, and you are connected wirelessly via Bluetooth, it will not play the music.
Additionally, the voice commands for Artist, Playlist, Songs, etc from the MyLink system will NOT work with the iPhone unless you are connected via USB.
Hope that helps.
Cheers.
If you have android and are listening through Bluetooth, I've noticed you can not add new stations through your truck you have to add them onto the app on your phone prior to connecting to the truck to get the station.
