Well I got the whole assembly out. Had to use YouTube as there was one hidden bolt.
What happened was GM wraps the little wires around a couple pins to hold the wires in place.
The pins made the wire so tight that the bulb would only turn about 80 degrees. That last
10 was stopping the bulb from being able to be removed. Once I removed the wire from the
pins the bulb came out no problem. Knowing that now I wouldn't need to pull the whole assembly
as the wire came be pulled from the pins with the assembly in place.
Thanks
Jim
