2001 Silverado 2500 HD 8.1L Starting Issue
I'm trying to do some research here to help my dad out with an issue on his truck. It's a 2001 2500HD with the 8.1L engine. Suddenly the truck just won't start. When you put the key to the start position it just makes a humming noise. He's verified the battery is good and tried jumping it and removed the starter and had it tested at the parts store and it is fine. Any ideas? He talked to a local mechanic as well as to techs at the dealer and both sources suspected an antitheft device malfunction. The tech at the dealer told him it's most likely a box that has to do with the anti theft device which usually comes with a new key when bought and the price is $800 just for the part? Any ideas on if it could be the problem and is there any way to bypass this thing? I've heard of other GM vehicles of this vintage needing a new ignition switch but I've never heard needing to replace the "box"????? Any info is greatly appreciated! Thanks........
How many miles on it? Is it an auto or manual? If it's an auto make sure the shifter is all the way in park. If manual it could be neutral saftey switch...
It is an auto with just over 100k miles. I stopped in to check it out for myself last night and it makes like a electrical short sounding buzz from the lower left part of the dash. Also the radio flashed error and the wipers and other lights are really weak. What would be under the dash towards the far driverside? When you here the buzz you can almost sense a vibration from back there. Thebuzz only happens when you attempt to crank the engine.
is engine crank at all?
check your ground cable, also test starter wire at solenoid with a DVM (digital volt meter)
Update!
So it is a bad battery but not in the form of voltage. It is a Diehard Platinum with both top and side terminals. Well the side terminals attach somehow to the top posts in the most funky worthless design I have ever seen. Like some plastic piece which the side terminal is attached to goes in through the side of the battery under the top posts. Well the negative side I noticed was loose so by just removing the negative side cable and just touching it to the top post and wha la the truck started. He was going to get some top post adapters to try and make it work that way while he can get to sears to see about warranty but I told him to get his money back and get a different design of battery because that problem could surface again while away from home. All I know is I will never buy a battery from sears. That's for sure!
  • 3 weeks later...
my father had this issue with a 5.3 in a 1500. turned out to be related to the security system. Truck would not start, sit there a while, good to go. Ignition interlock maybe???
    • I tried tapping it.  This might sound like a dumb question, you should feel vibration or some type of noise when it turns on? Can someone please verify? Thank you all!
    • I feel better now for my own view point and actions or lack there of towards the dealership service theme reading your post and others. GM corporate is who offers the two free oil changes on the HD trucks and I bought my truck in Feb of 2025 and those oil change offers run out within 2 years I believe and I highly doubt I will be using either one of them. I had asked if I could officially give those free services to another customer ( a friend ) and they said no, its all a GM corporate thing based on the vehicle in question. What that service advisor did however was go into a little story about how such and such customer was denied engine warranty because he had done his own oil changes because then they are not documented ... you see where that goes and so an employee playing the game of scaring the customer into having the service work done there most certainly triggered my thought process. At a later date I did talk to the person who handles warranty claims at the dealership and she said to be sure to document the oil changes and keep receipts for the oil and filter ( coped the receipts from cases of Mobil oil and case of filters I bought from them ) and the vehicles VIN, the date of service, mileage etc and staple that together as a record I would give them if that was ever needed and I keep my own log book for services for each vehicle as well. Oh and about 8 months after I bought the truck the dealer starts calling me to offer a maintenance service since they haven't seen my vehicle show up on their system ... for the mere fee of 300.00 Canadian to change the oil and rotate the tires and a few other minor checks and I declined the offer, I get the call again a couple of months later for the same thing and she could tell I was not interested and she asked if they should take my name off the call list and I said yes, do that !.    By the way did you happen to keep your factory oil filter to open it up and see the surprises inside as I expect some will show up as per the odd little sliver of metal shaving and particles that the filter does trap along with bits of grey silicone sealer that come off of the inside edge of mating surfaces. I have cut open every filter so far on my truck although few miles but have changed the oil often and the second filter was vastly better with very little of anything, that first filter was the unsettling one as I expected it would be.
    • I get why they do this…but man…not ideal. I only extract on inboard boat engines because the drains are buried and even then I hate it because it’s easy to leave a quart behind with that method.   They should market it as an “oil refresh” not oil change!
    • I only get oil changed where I can watch. Valvoline pulls through the dipstick into a see thru glass. When done they show me the dipstick. About the only way they can mess up is using the wrong oil. But that secret wouldn’t stay secret long. Honda uses TQ wrenches on everything. You can watch through a plate glass window. Discount tires does that with tires. Trust but verify.
    • I would not argue that with you. It would be pointless to argue against the truth and you speak the truth.    My question and in fact the entire point of this thread is an exploration into the levers of wear which happens no matter how well we maintain our powertrains.    Some of these levers we exert a good deal of influence over which can and do result is lower wear, longer powertrain life. Some others we are sort of stuck with.    An engine is typically done when the ring to bore seal no longer is able to do the job effectively. Normally the first thing to go in a engine otherwise well maintained and adult driven is this seal.    Looking into the means, methods, products and attitudes that influence the rate of wear seems a worthwhile inquiry to me.
