XM Radio Reception
b1gted
I wanted to add that my radio reception in my 14 for FM and FM HD is lousy. The HD is basically worthless because it goes in and out all the time. I thought turning off the HD switch it would stay that way but that is only temporary. Has anyone found success with improving this situation?
  • Replies 38
blue tooth your phone media lol.. Radio blows
  • 1 month later...
Ive had to refresh my SiriusXM signal 3 times since I bought my 2014 Sierra in September. It will be working fine and dandy, a few little short cut outs here and there when I go by a tall building or under a bridge, I can deal with those.
The ones that get me annoyed are where I start the truck after its been in the garage all night and the screen shows all the channel information but there is no sound. If I switch to a normal FM or AM channel there is sound (so It's not the radio). Sometimes, if I let it sit outside for a while it will come back on fine. Other times I have to manually call the XM refresh line and have the automated service send a signal to my radio to refresh the signal.
This only happened once in my previous vehicle in two years, and NEVER in a vehicle I had a few years ago with an aftermarket antenna and XM adapter. Kind of annoying a 47k truck cant keep the damn signal from going out every few weeks.
I don't know if I should be complaining to SiriusXM or my dealership. Seems like its on both of them a little bit.
I've had the same issue of starting the truck in my garage and there is no XM reception, but the station is tuned in and lists the song & artist, but no sound. Flip over to FM and it works, so it's not the sound system. Anything further from a dealer/GM response on this issue? Seems like it will keep me from signing up for XM if i have to restart the truck to get reception!
I haven't had any issues since I last posted.
Sent from my iPhone.
When my XM loses audio but is still displayed on DIC if I tune to channel one or zero the audio comes back and I can tune to another channel. I have no idea why this corrects the problem but it has worked several times for me. XM signal strength is about average on my truck FM is terrible(as posted on another thread).
  • 1 year later...
New gmc owner here. Just picked up a 15 denali 1/2 ton. Been a ford guy for the last 12yrs. On the same road to work my f150 would only loose signal in one heavy forest area. The new gm will drops off constantly on my drive. The fm is even bad compared to the 12 f150 I just traded in..pretty disappointed. But the bose sounds better imo over the ford so that's a plus..
x2. My XM cuts out in places it shouldn't and it really doesn't like any sort of tree cover in front of it. FM is decent though. Bose system makes it all worth while too.
My truck is the same, loses signal quite a bit in these hills around here. My mom had a grand prix that did the same thing. Funny thing is I also have a Grand Cherokee with XM and it rarely loses signal.
  • 1 year later...
It's pretty bad in my 2016 Silverado. Mainly in town and definitely in specific areas in town.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,346 Guests (See full list)
    • Yes that's right, it's the upgrade that includes the overload spring and all that stuff.   Someday when I'm empty and going by a scale I'm going to stop in and get some weight readings.   Exactly  you should have the ability to change individual settings, in in Canada so I'm driving with kph but then I'm stuck with kpa when I want psi lol
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
