how to change fog light leds
How do you change the fog lights on 2014 Sierra want to put in replacement bulbs I bought from ijdmtoy plug and play....I want them to match my led driver lights close as I can can stand yellow lights
  • Replies 61
Remove the Wheelhouse liners and then from the back of the light release the locking tabs and pull light assembly out through the front
You don't need to remove the wheel liner. I did it took me about 15 minutes is not easy. But with some flexible fingers you can get it done. There's two clips you can see on your replacement led lights, use them as a guide. You can press them one at a time or both if you can get your fingers in there. They're located on the top and bottom. The bottom one is the trickier one. Good luck!
Can you guys post a link to the replacement bulbs you used? I assumed they are "whiter / more blueish" like the LED daytime lights?
Are they also brighter than the stock lights? How do they look?
Sent from my XT907 using Tapatalk 2
Keep us posted...pics of install and finished product would be helpful
I'be been looking at the CREE projector bulbs. They are pricey at $50/pair
    btm
    btm
  • Who's Online   6 Members, 0 Anonymous, 1,466 Guests (See full list)
