Which tires came on your allstar package?
svtkidd23
I noticed I do not have the same tires as others with the 18's and all star package.
I have the goodyear assurance ac 265/65/18
My buddy has Goodyears but I think they are Sra's? they have more of a AT look
On mine the "all terrain" tires were a $200 option. And I have the Goodyear Wrangler SRA's.
I have the sra's and there nothing to brag about. They are pretty noisy for the amount of tread they are lacking.
Yep and not so good in the wet. rough ride. Here is tire rack survey:
https://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Wrangler+SR-A&partnum=665TR8WSRA&vehicleSearch=true&fromCompare1=yes&autoMake=GMC&autoYear=2014&autoModel=Sierra 1500 4wd&autoModClar=Crew Cab&tab=Survey
Mine - all star edition+white diamond edition - Goodyear Eagle LS2 275/55r20
Shitty tires. I will never use those again
Sent from my Samsung Galaxy S4 using Tapatalk 4
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 263 Guests (See full list)
