Please vote :)
RyanbabZ71
  • 3 weeks later...
Nice! Those were made about an hour away from me (still might be just not sure) I remember the owner coming up to the Ford/ Subaru dealer I worked at at the time to snap some promo pics
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
