WeatherTech Side Window Deflectors
mzodarg
  • Replies 83
Here is a vid of the weathertech install with clips. (different vehicle, same principle I'd assume)
The AVS' look like they would just as good for a lot cheaper though.
Those with the Weathertechs, do the fronts come down the edge in it's entirety? Some truck pics on their website show them going all the way. The AVS' only go to the side mirror it appears. Can anyone confirm? Thanks
Mine are like pictured (Weathertech)
How do you like them? I had similiar on my nissan sentra when i was younger and it would whistle at high speed driving and it really cut down on the amount of air that would come into the car when i had the window fully down.
Did you notice added wind noise with them?? I noticed some more when I put avs inchannels on my grand prix
I always liked WeatherTech Side Window Deflectors. I had them on my 2002 and 2008 Chevy regular pickups. They are good quality and I had no issues with them. I just got the fronts. You have to wipe them down after a truck wash to avoid spotting.
WeatherTech is dragging their feet for making the side windows deflectors for the 2014 Chevy regular pickups. The pickups have been out a while and there is still no word if they are going to do it. I went with the AVS in channel ones and they are not as good quality as the WeatherTech but may be okay in the long run. They were only $38 total including shipping. With the cold weather in CT, I had to wait for some warm weather to get them to stick properly. There were a lot of good reviews on them.
I need time to make a final decision. I didn't want to wait for WeatherTech. Their loss maybe.
Thinking of AVS in channels as well for my ride. Price sounds good and looks sharp. Just want to make sure they'll be solid.
Sent from my DROID RAZR HD
Thanks for the confirmation.
As a note for the AVS', the website http://www.lundinternational.com/products/ventvisors-side-window-deflectors/in-channel-ventvisor-4pc/?brand=avs#.UypODKhdV8E shows the same part number for crew and extended(double) cab. I found a set on ebay: http://www.ebay.com/itm/310853624794?item=310853624794&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr and the fit chart shows extended and crew. I emailed the seller and verified, they do fit the double cab model.
  • 3 weeks later...
Having trouble finding weather tech and/or AVS for my '14 double cab. Looking on amazon for best prices....anyone have better luck?
I found some avs on ebay. Link is a couple posts up. As for wt's, their website is the cheapest I saw.
Sent from my SGH-M919 using Tapatalk
#194528...I'm unsure how the crew cab and extended cab are the same "size". Figured the window is bigger on the crew cab. Hmmm....
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
