range afm delete
primomarcelino
Who has it and what's the review? I emailed vendor and his emails do not make it to me. I only know he emailed me through a survey of the service I got. Vendor stated it ia available for 2014 and people are using beta version. What is beta? I notice that some camaro users are comparing versions 1 through 4. How can this units firmware be updated? Usb cable?
Beta is a testing phase. And the firmware probably is only updated using an interfacing device that has an adapter for an ODBII port then hooking it up to a computer and installing the updates.
Blackbear tuning was great! I actually had them tune my old 2002 as well as my dads 2007 suburban. They really know there stuff. They might be more expensive. But they know how to make a Chevy motor purr like a kitten. I was able to get 17 mpg on the highway with my 02 and that was with a lift and bit wheels and tires. I never had it dyno tuned but it was putting down some power.
I'll probably do a blackbear again any day.
Sent from my iPhone.
I have BB. I would try the range first and see what it does for drivability. Then BB if not happy. I did a mild 89 octane tune. Only problem I see is torque mgt on the 900s and I assume the '14s is either on or off. No way to go say 70% tq mgt off...
Im pretty sure the TM can be detuned on the new trucks as well. But maybe I will send a message over to the guys at BB to ask.
BB was the one that told me T/Q control on or off. Maybe I misunderstood or just the 900s??
Torque management is the programming that cuts power from the engine to prevent driveline shock/abuse. The consensus seems to be that you can safely remove fair amounts of it without harming the transmission or other components. Disabling it will make the truck more responsive.
Anyone get the range yet? I was wondering if there are any problems with it. I read in some vehicles it can mess with the stabilitrack.
From what I've gathered I think the Range device for the 2014 trucks is in a "beta" testing mode. Not available to purchase from their website, but some people have them and are testing them out for Range. Or something like that.
  • 5 months later...
I have been "Beta testing" the Range AFM for about 7 months now and its worked very well. Just last week my engine light came on and I got a "Service power steering" and "Service 4wd", but both were working fine. I drove the truck home, parked it and removed the Range. About 30 minutes later I started the truck back up and the check engine light was off and i did not receive any messages regarding the power steering and 4wd. I then e-mailed Range about what happened and within 2 days I had a tracking number for a updated replacement Range unit being sent to me. The moral of the story is, although there are going to be glitches because of how new these trucks are, the people from Range have been very good about answering my questions and sending me an updated version with no questions asked!!!
Note: I am Beta testing for the 4.3...
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
