I think they'd be the same for a 1500. The 2500/3500 might have a slightly different hood contour.
The thing about those and the roof mounted lights is that the hood becomes a large reflector and reduces your night vision, unless it's flat black. White would be the worse case. Darker colors might be ok. That's why headlights are on the front of a vehicle.
A buddy of mine (member PDV127) has a summit white all terrain and a 55" curved bar mounted above the windshield. He said the light reflects off the hood but with how much light it puts out, it doesn't bother your sight at all.
Sounds like your lights are tight with minimal "spillage". Also what color is your hood?
White with white hardtop. The key is the spot beam, and the angle in which they are oriented at.
This is a picture of my dry fitting the light bar and the mounting bracket.
ba8b199d-4a5e-4c5e-9bca-935434ffadd0_zps
And the finished bracket mounted to rad supports. I cut the corners to allow the bracket to fit behind the plastic shroud. I vinyl wrapped the aluminum bracket.
7e6669bd-3f01-48fd-abe7-8bbeeabe774e_zps
I will add photos of the finished product behind the grille, I am extremely happy with the fit and finish and the light output is awesome...couldn't care one little bit that the highbeams suck in these trucks now :thumbs:
Can you measure the diagonal supports please? I need to know that the circumference is please.
My truck is back together now but I am pretty sure those rad supports were 1" square if i remember correctly.
Yeah I tried but couldn't get the tape measure to sit just right to get an exact measurement looked like between 7/8 and 1 inch so I didn't want to give the wrong sizing.
Sent from my SAMSUNG-SGH-I997R using Tapatalk 2
ok so for -18C this is as clean as it is going get lol
picture of light bar behind the A/T grille
oh and changed colour on the emblem btw
e544b087-fca5-4356-a8c4-abee792ff2cd_zps
Edited by 613 IRDM A/T
what size light bar is that?
That is a 32" curved light bar. It fits perfectly and the 2" space between the bars in the grille are exactly the same as the thickness of the lights.
Looks great. also forgot, what brand?
Had a local fab shop make me some custom brackets for these rigid D2's. Didn't like the rigid ones. Wanted something more appealing. These guys are willing to full on CNC aluminum ones if enough people would order them. These are steel brackets but more than likely going to have them make some better ones where they can do a full one piece bracket.
Edited by iicoolbreeze
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 753 Guests (See full list)
