Which one are you using?
I got the totron one. Has on/off, s.o.s, and nine different flash patterns
Do you have a link? Can it work with any brand light?
I had one on my truck and it only lasted a few months before it shit the bed.
just ordered my OZ USA light bar for my grill, can't wait to get it and install it :)
so does a 30" - 32" light bar fits behind a grill with NO problem ??? I think a dual row will be the best (straight) ?? Any information will be helpful. Thanks
A 32 inch bar will fit behind the grille with plenty of room. I have a 32" curved double row. You will have plenty of room for it
Sent from my SM-G925V using Tapatalk
Thank You.
Thank You.
Lets see some pics when you post put a bar in the grille
I ordered the double row 30" curved light bar and ill try and duplicate the brackets that kerrslight made for his...they shouldnt be too hard to replicate
Let me know if you have any questions when your installing it. The measurements and getting everything lined up in the hard part. Mounting and assembling is easy.
Hope you enjoy the bar!
may I ask were you order from , and the make . Thanks
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
