I have a set on mine.
More details? NVM just say your sig, got anymore pics? like how the bolt up?
Edited by CptMcSaug
More details? What mount?
I would like the info - mount , photo's up close ?????
I'm interested also...
Do they get in the way of opening your hood?
I too have had these for a while. They've gone drastically up in price since I bought them. The mounts are installed between the hood and the hinges. I've had mine for about 7,000 miles with no issues or loosening.
Amazon Link: T-Rex (p/n6390281-Bk)
I can get some pics of the mount today when I get home from work. They bolt between the hood and the hood brackets. They do not interfere with the opening of the hood at all.
Well my rigid dually spot lights came in and I'm not sure where to mount them.
Sent from my GT-P5210 using Tapatalk
Hey guys, I haven't posted on this forum yet but I have read and got a lot of great ideas.
Forgive me if this has already been posted but i put in a rough country 30" curved light bar behind my grill. The light bar itself is more pricey than a Chinese light bar but seems of good quality. The real reason I bought it was for the mounting bracket. It's awesome, a few bolts and that's it. No cutting, drilling, or measuring. And there wiring harness is of excellent quality also. Wrapped in braided nylon of some kind. Plug and play with the Totron wireless remote. And that remote does work with the home link. You can order the bracket without the light bar if you wanted to find a cheaper one (I'm assuming other light bar brands would work but I would check your actual sizes). And on there website it only has the Sierra bracket (they say the Chevy bracket was different?) in a package with a single row light bar. I just called and ordered the double row 30" curved with the gmc bracket. Great customer service just call with any questions and they have really fast shipping. Looks great on my 2015 Sierra all terrain, and my buddy did it the same way on his 16 sierra Slt.
Rough country part #s
Bracket for gmc- 70620 $34.95
30" curved dual row light bar- 72930
Link to remote from Amazon
http://www.amazon.com/dp/B00UR2DIRI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1VCUEXC0WYJIA&coliid=I1DCFS6XVN5TLT
Link to install instructions of brackets that has pics
http://s3.amazonaws.com/roughcountry/install/927062000.pdf
Edited by Ludasooner
    White.6.2
    White.6.2
  • Who's Online   2 Members, 0 Anonymous, 610 Guests (See full list)
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
