Since this thread seems to come alive every two years I figured I'd do my part.
Just thought it should be pointed out that the poster first several posters are incorrect about the "little rubber tubes" that come along with the pin seals. Those little rubber tubes are the guide pin bushings and slip over the small end of the caliper guide pins. You have to dig the old ones out of the caliper bracket to replace them
  • 11 months later...
Hi I have a 2009 Chevy silverado 1500 hybrid two mode 4x4 I have replaced all of my brakes calipers roders hoses all of them a my brakes master cylinder to so why does my back brakes keep grinding  what can it be
Hi I have a 2009 Chevy Silverado hybrid two mode  1500 4x4 I have replaced all of my brakes and the back brakes keep going bad and grinding  and I do mean I replaced everything  I replaced brake master cylinder (new) calipers on all 4 rotors on all 4 and brake hoses on all 4 can some one please tell me why the back brake keep going out and grinding I only got 3,000 mileson the back of the truck
  • 5 months later...
I always change the brake hoses when changing calipers. A good indicator that your hose has a restriction is that when you crack a bleed screw, no fluid drips out. I recently replaced both front calipers on my 2001 Sierra, new hoses, nice high pedal, like new. AC/Delco remans are $47/each on Amazon, and they send you $30/core when you return them, and they pay the ship. That's $17/each!
Well, you didn't mention the ABS pump and you might have selected the wrong parts and or put them on incorrectly.  The wear indicators go on the inside for example.
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 494 Guests (See full list)
