funny impromtu race today...
TJay74
Stuck at a rail road crossing, had a newer Mustang with the 4.6 next to me. We are waiting for the crossing guards to lift up and we both start easing across the tracks, I hear him roll into it so I oblige thinking I am going to lose. Nope, by the time the truck got into 2nd I was pulling on him slightly.
Surprised me to the say the least, 5500lb truck with 420hp pulling a Mustang with 280hp that weights 3800lbs. The other driver was surprised as well.
First and last kid time for me, back to driving like a senior citizen.
*all was performed on an enclosed racing course that happened to have a faux railroad "race gate" and a story added more realism to it*
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
