Christmas presents
Jeff48
  • Replies 49
Managed to scrape up enough to get my new shotgun!
Benelli Super Black Eagle II in Realtree MAX-4
Sent from the side of the road...
I need a semi auto. My browning citori xt trap is my big $ gun.
Sent from my SCH-I535 using Tapatalk
Still haven't shot my new gun. So damn hard around here to find land to shoot or have bonfires
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
