Christmas presents
Jeff48
What did someone else get you for your truck? I got plasti-dip and my wife is doing my emblems while I watch...closely!
  • Replies 49
*Moved to the off topic section
Nothing truck related this yr. Did get a set of rims for my camaro though. Couldnt believe my wife agreed to this gift but when she said go for it I jumped online and ordered.
Not sure since Christmas is tomorrow, but my guess is nothing
Wife is getting me leather jump seat covers for my truck to go with my new escalade seats.
Buying myself my trans this weekend I don't have any presents Ethan said he got me something but he's not here till Friday, I got him a carhartt he said he didn't want me to waste my time on truck parts. Lol
Sent from the toilet
His have the smooth lining and they're kinda old so I got him a quilt lined one like mine in a metal gray color he's gonna love it
Santa brought my son a C7 stingray!
Ryan
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
