Rust on front bumper
So i washed my truck the other day to get the salt off and noticed i am getting some rust pitting on the chrome front bumper on my truck. Conveniently i am about 2k outside my bumper to bumper warranty. Is there any remedy i can do my self to curb this problem?
Thanks in advance.
I just clean the spots with chrome polish In the spring... If you bought it new you might give it a shot and see if GM will cover it... Sometimes they do sometimes they don't
Doesn't rust have a longer warranty than bumper to bumper? I'm on mobile so I can't see what vehicle you have.
The rust warranty is for rust through, not surface rust/corrosion.
Got it.
Try the dealer route to see if they will replace it.Some 2011's had bad chroming and the dealers were replacing them. Mine was one of them.
