Ai off-road led !
bigdeer1
In all honesty I've never wired off road lights before.. I figured this would be a way to learn the hard way
Lol... Also. Would a relay be necessary ?
it depends. do you want it to come on like when you put the truck in reverse or if you want it to come on with any other lights if thats the case you could use a relay or just tap into a wire that has that power feed that you want. if you want to control when it comes on then no just hook it up to the battery some another wire if youw ant and then run it to a switch inside the truck. just make sure to use an in-line fuse so you dont burn anything up in case it shorts out somehow down the road.
I'm thinking backup light. I can't find a place for a quick easy mount on the front... I don't wanna take apart the grill just for 1 small light..
    juggernautusa
    juggernautusa
  • Who's Online   1 Member, 0 Anonymous, 493 Guests (See full list)
