Iraq TV Guide
pacodiablo
Iraq TV Guide  :crazy:
Sunday:
0800 - My 33 Sons
0830 - Osama Knows Best
0900 - I Dream of Mohammed
0930 - Let's Mecca Deal
1000 - The Kabul Hillbillies
Monday:
0800 - Husseinfeld
900 - Mad About Everything
930 - Monday Night Stoning
1000 - Win Bin Laden's Money
1030 - Allah McBeal
Tuesday:
0800 - Wheel of Terror
0830 - The Price is Right if Osama Says it's Right
0900 - Children are Forbidden from Saying the Darndest Things
0930 - Taliban's Wackiest Public Execution Bloopers
1000 - Buffy the Yankee Imperialist Dog Slayer
Wednesday:
0800 - Beat the Press
0830 - When Kurds Attack
0900 - Two Guys, a Girl, and Pita Bread
0930 - Just Shoot Everyone
1000 - Veilwatch
Thursday:
0800 - Fatima Loves Chachi
0830 - M*U*S*T*A*S*H
0900 - Veronica's Closet Full of Long, Black, Shapeless Dresses and
Veils
0930 - Married with 139 Children
1000 - Eye for an Eye Witness News
Friday:
0800 - Judge Saddam
0830 - Suddenly Sanctions
0900 - Who Wants to Marry a Terrorist Millionaire?
0930 - Cave and Garden Television
1000 - No-Witness News
Saturday:
0800 - Spongebob Squareturban
0830 - Who's Koran Is It Anyway?
0900 - Teletalibans
0930 - Camel 54, Where Are You
"Spongebob Squareturban" :crazy:  :smash:  :smash:  :wtf:  :cool:  :D
