Seat bulletin
bcazier
Great news! If someone hasn't already broken it...I was just at dealership to drop truck off for third time on seat movement and the advisor said a bulletin was out for the seat. Maybe a week it's been out. Said gm is working on a shim or something to fix it but the part isn't available yet. I was ecstatic to get the news
There was a bulletin issued in August for loose cushion fix. Do you know if that is the bulletin they are now referring to?
  • 1 year later...
I dropped my truck off a month ago to get the seat fixed. They said they were going to replace the seat frame. However, they had it all day and never touched it so I took it home because I needed it that night. Well then I took it back a week ago and I was told they had received the bulletin on how to fix the issue so I was relieved. $ days later it started to shift again and is just as bad now as when I took it in. I told them I would bring it back when they got a real fix for the seat issue! I guess the rubber and hose clamp is the way to go... I hate the fact I'm having to do it myself, but it's a pain in the *** to get my truck to the dealer in the mornings only to have them say they need it another day! You would think they would put you above the other issues seeing it is a returning problem!
Yeah I can confirm that this is supposed to be the fix, 1.4hrs of labor to get it done: PI1183 dated Feb 27, 2014.
Requires a lubrication of the front seat pan pivot points, addition of 2 pin type trim fasteners to the front seat cover, additional seat cover clips, an the installation of shim clips between power seat vertical adjuster actuator and the seat frame. It is an excessive clearance problem on the power seat to the seat frame.
I hope this works. I can even live with the other problems with this truck but the seat issue ruins the driving experience. Sometimes a guy just wants to leave his cell phone at home and cruise a little. :driving:
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,552 Guests (See full list)
    • I’m definitely interested to hear the end result here.
    • My 2025 Silverado 1500 had to receive a brand-new engine (long block) under warranty last month at only around 16,500 miles. Before the replacement, the truck repeatedly displayed "Engine Oil Level Low" warnings, even though the Oil Life Monitor still showed around 50% remaining after about 6,000 miles since my last oil change. After seeing the warning several times, I checked the dipstick with the engine cold, and the oil level was completely normal. The next day, the message escalated to "Add Engine Oil." At first, I assumed it was just a faulty oil level sensor, so I brought the truck to the dealership. After inspecting the engine, they found internal cylinder wall scoring and ultimately replaced the entire long block under warranty. Before this happened, I was planning to install a 4-inch lift and suspension upgrade on my truck. After needing a new engine at just 16,500 miles, I honestly don't see the point anymore. I also contacted GM to ask whether my vehicle qualified for a buyback, but I was informed that it does not at this time. Anyway, this experience has left me with serious concerns about the long-term reliability of this engine. I sincerely hope NHTSA expands the current investigation or recall to include 2025 model and performs a thorough inspection of affected vehicles. My biggest concern is that these engines may fail shortly after the powertrain warranty expires. If GM truly stands behind this engine, then at the very least, please consider extending the powertrain warranty to 10 years for affected owners. That would go a long way toward restoring customer confidence.
    • Without exception but then I'm the odd duck, right? I know what goes into that test, how it is calculated and thus how to beat it. But EPA values are often not beaten by the general public and the government has in past years adjusted the means and methods to come to those values to more closely approximate "Joe Average".    The only real trick to beating that EPA average is don't drive like "Joe Average".    It's the same method you used to profit from "Economic Migration" and in doing so beat the 'stats'. But you, like me, are not "Joe Average".     The thing you don't seem to grasp is this "Purchasing Power Index" isn't forward looking. It doesn't predict what it going to be but looks backward and states what it was. They are not telling us what the THINK, they are telling us what they MEASURED. Example:    Wife says "I'm going to lose 40 pounds by Christmas". May she does, maybe she doesn't but the doctors office who weighed her when she made that statement and again at Christmas only REPORTS what the RESULT was. You and I can banter about what was possible and what aunt Tilly did till the cows come home but the result is the result. Arguing otherwise is.....irrational. That's all I'm saying. This isn't about:      What you are calling a 'Statistic' is a RESULT not a CALCUATION and as a result the RULE. Like gravity as a rule, it can not be broken.
    • Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.   I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window. To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.   I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.   I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.   Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I have 2 choices.
