Anyones clock gaining time?
Today I noticed my clock was about 7 mins faster than normal.
It could be the nice temperature change (30s to single digits).
oh yea also my tire gained air pressure  ???  ???  ???
I check them once a wk and the last time i checked them (cold truck wasnt driven that day yet) the gauge read 54 psi and the prior time (also cold and truck wasnt running) it was 52.  I tried another gauge and same reading
Wonder when my mpg will start gaining  :crazy:
My clock resets itself to a random time occaisionally (I believe there is a TSB about it), but it doesn't "gain" a few minutes here or there.
IF you checked your tire air pressure at the same ambiant air temp, then it would be strange for it to "gain".  If it was 15-20 degrees warmer (say 15 degrees vs. 30 degrees) I could see a couple of PSI higher on the warmer of the 2 days.
If your MPG's start to gain too, then I wouldn't complain about the other stuff too much!!!   LOL!!!
