Daniel,
Was it one complaint or several that got you the updates? Could you post up the service number for the PI that was used by chance? My HVAC operates funky and the next time I take the truck in for the oil change I was going to have them look into reflashing the HVAC module.
Daniel,
It wasn't the HVAC module, it was the large radio display in the center, but the fix included the HVAC system which apparently runs through that display. When you go in, just ask them to check to see what outstanding updates are available for you, and if you're still less than 36K miles it should be done no questions asked. The particular update I just had done was to the HMI module.
You are correct in that sometimes they do ask for a symptom that matches the needed update, so I gave them a couple. Here's what the repair ticket says:
Radio favorites will disappear and then come back after key cycle; voice prompt length changes itself to long after being set to short; reference PI 1126D. Performed PI 1126D, reprogrammed HMI module 2881168
I think the 2881168 might be an internal code and what you really need is the PI 1126D
There is a sequence of buttons they press on the dash that pulls up your software version; if the latest software version is newer, you qualify for the upgrade. I wasn't aware until after the fix it would improve my A/C performance, but it did. Specifically, the fan speed is more gradual in its speed changes, it doesn't use recirculate as much, and when I hit the A/C button to manually turn the A/C off it turns off right away (before it would think about it for awhile).
I've had so many software updates in the short 15 months I've owned this truck I have lost count. On the one hand it's frustrating, but on the other it's good that each update has made an improvement. So whenever you're in for service, check to see what's available. Good luck with yours.
  • 5 years later...
On 11/25/2014 at 8:19 AM, DanielAcosta said:
It will correct the shift points and V4 operation, which in turn improves your fuel economy. After 34K miles I'm still averaging 20mpg overall, which seems pretty good to me for a 4wd lifted truck with a stock epa rating of 16/22/18. Take time to calibrate yours with a gps for best results. Even though my tires are 34 inches tall, the Hypertech entry that worked best for me was 33 inches, which is the height of the tires when compressed by the weight of the truck. Good luck.
Which hypertech calibrator did you get?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
