Just got an update from GPC, the souls have my console in by end tomorrow or Wednesday at the latest and then hey will ship it out to me.. Can't wait, I've been waiting for almost a month for all of these parts for the console..
Whats the difference between the denali and non-denali console? I'm looking to do this after winter.
I have the cocoa interior. Looking to get a parts list ready.
I have the weather tech over the hump floor liner...I'm wondering If i can install the console over the mat? Maybe I'll need to trim slightly?
I am also confused on what panel to buy...they have a lot of options. I need to take a picture of the interior.
Insights? You guys know your shit.
Mike
Edited by DeePa
you need this panel
http://www.ebay.com/itm/2014-2015-GMC-Sierra-SLT-Console-Upper-Woodgrain-Trim-Panel-OEM-22995109-/191438467387?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c929f313b&vxp=mtr
My friend ordered from the same seller and it showed the missing 110v outlet missing like in the picture but she received a new one. So you might have the same luck.
Thanks for your help. I cant find that listed part number on a parts lookup site. It looks like it is just the plate, no cup holders included. What is the color code?
The options are :
Reverse Tartan
Off Road Carbon
Grand Momiji
Grand Lace Wood
Quilted Maple
Synthesis
Curly Koa
Devenport Wood
Mineral Caster
Thanks,
Mike
Power and ground to the 6 pin connector and USB cable connected to the outlet and HMI control module. There must be some type of communication because I have always on power and ground to the USB outlet. Yet it goes to sleep about ten minutes after key off or opening door. and wakes up when the driver door is opened or key is on.The correct 6 pin connector is very expensive so I just used the terminals and shrink tube to keep from shorting. I would have to find the part numbers for the terminals. The cable I bought ( the only we could find in the GM part catalog ) plugs into the outlet but not into the module without some customizing. Had to shave the connector down with a razor blade.
Hey tbarn, do you have the part number(and pic) for the usb cable mentioned above...my apologies if I missed it in any of your subsequent posts.
Also, you mention that one end plugs into the HMI control module. What is best access to that module, from underneath with console removed? or through front bezel with console in place? or other...? Thanks in advance.
So I got my console in last night. I have some wiring solutions that I am going to try next week. I ordered a mini sub splitter in attempts to get data and charging working. I am also going to get some new wiring ends male and female wing same number wiring options and use that to see how it works. I had to buy the Denali console since it was the only one available. It is the exact same only difference is the wiring harness that I have found
Nice, if you can document your progress with pictures it would be really helpful. I should have mine by the end of this week as well.
I had the same question for tbarn, he responded to me with part number 19303328 for the usb cable. The HMI module is behind your glove box.
Thanks James (and tbarn)!!
well, got everything working except for the console light and front usb data (charges only) on the front. I took the old harness, added an additional 12 volt plug and usb power plug to the harness from the new harness and made it into one modified harness. everything seems to work fine.
Edited by jamesdburton
Popped the front tray off of a new Silverado with factory console today.
Do you have a part number for the male end of the plug that could plug into the female that came with console? Hoping I can get it to work with some splicing
Finally all my parts have are in and will be here Tuesday, I will post pics and any information I can when I get it all installed.. Can't wait...
Edited by thrasher2010
Are you talkin' the large white/gray connector?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,211 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
