Thanks, I'll include that in my order. One more question/concern: My truck….2014 Sierra WT/SL Reg Cab, and I would like to replace the stock, solid dark grey (black?) piece around the audio & a/c cluster to match the upper trim panel for the console. The limited information I have leads me to believe, the color "synthesis" is the only color that's available in both pieces. Goodness only knows what color that is!!!!?????
Colors available for dash piece: burnish, black, axiom, synthesis, high country silver, and combat.
Colors available for console panel (non-wood): off road carbon, reverse tartan, grand momiji, synthesis, and mineral caster.
Since my sources are limited…..any help on matching colors would be greatly appreciated.
I'd like to know this too. I want to change out the console and door pieces in my truck to match the trim in the center stack and vents.
Take a look at post 134. Radio bezel and console trim are synthesis.Lighting makes console trim look lighter than it really is. Parts are best ordered by VIN. Look around at dealerships till you find the trim you want and write down the VIN. If they are still backordering the console, you will need a valid VIN from a truck that is set up the way you want. Otherwise GM will kill the order.
Edited by tbarn
Tom, great tip on including the VIN. I have been searching the Sierra without any luck finding the color I wanted, and after your post I finally noticed your vehicle is a Silverado, which led me to search the Silverados, and bingo……found the color I wanted. Apparently there's some separation of colors between Sierra and Silverado. Thanks for the help.
So the p/n 22995086 is the console plate that matches the radio bezel? I saw in another thread about the door panel pieces that the synthesis console plate is p/n 22995093.
We really need a part number thread here.
Just an idea: look into hydro printing. You could every piece of your interior for $200ish (depends on the shop. Could be a lot less.) and they would all match.
Go Army! GO ORDNANCE!!!
22995086 and 22995093 are both synthesis front plates. One has 4 outlets. One has 3 outlets. 22995093 plate is minus the 110v outlet.
Great thank you! I almost had the wrong part!
  • 3 weeks later...
Don't know how much detail you need but try this pic for a start.
    LeeBob
    LeeBob
  • Who's Online   5 Members, 0 Anonymous, 596 Guests (See full list)
