Please help. I obviously missed something. In the console where's the huge grey plug pling into? I have all the plugs working in the front but nothing works inside the console...
Nm guys I just read I have to cut the grey plug off and splice my bad
Sorry for the dumb question. I read a few different parts list for the complete console swap . Which is the correct list that i need for 2014 crew cab. thanks
Not sure any are correct. Parts are make/model/vin specific.
it depends on your interior color
  • 4 weeks later...
  • 3 weeks later...
HERE ARE THE PHOTOS STRAIGHT, VERY EASY TO INSTALL AND SWAP OVER.!
not sure if you like leather, but you can get Katzins on ebay in black without the heat option for a few hundred bucks... i think its 500 ish.
I'm trying to swap the jump seat for a full console and I want to match the trim colors from my dash. My interior is black and I have darker gray trim on the dash and around the radio. When I look to order the Upper Trim Panel, there are quite a few colors available. Simply based on GM's color names, "off road carbon" may be a likely match. Finally getting to my question.....does anyone have a pic of an "off road carbon" colored Upper Trim Panel, gm part # 22995113?
Go to a GMC dealer online or visit one and look for the color on a center console in there inventory and get VIN number. Go to local GMC parts department with the VIN number and they can color match for you. You can do the same online which I did.
Does the console (part # 23466995) come with the armrest( top part of the console) or do you have to order separatorly .
Yes it does.
On the 2015, changes for the trucks note that there are USB ports in the glove box on trucks with the bench seat. I'd be interested in the pigtail that runs to it; where it goes, is it a branch off the harness that goes under the jump seat, etc.
I'm looking at swapping my jump seat for the center console in my '14, but the second set of USB ports don't have a hookup and that is keeping me from doing it. I'm thinking this harness from the '15 trucks could be made to work.
Yes it does.
Tbarn, maybe you could look at one of the 2015's on the lot and see what it looks like?
Thanks.
Thanks.
The 2015's are wired with two seperate usb outlets from two seperate connections at the hmi module. With or without full console. 2014's only had that setup with full console. So you could add the console and move one set of connections in theory. Not sure how easy but could be done. I added the second one on my '14 but the hmi module doesn't recognize it as a comm. port. It will charge though but I still have not used it.
Edited by tbarn
