Service Prices
Your coolant flush will be $79.95, Transmission Service $99.95, and Alignment $130.37.
If we need to knock out struts, it would be an additional $140.00
:crazy:  :smash:
A $270 alignment???
Does that price include the KY jelly?? :crazy:
 I'm needing to get mine checked this spring too.  I think that price is kind of steep.  Might do some comparison shopping to get a better deal.
WHEN ARE YOU GUYS FLUSHING your coolant (sorry bout the caps)
The coolant and trans prices arent bad and can live with that.  My alignment isnt bad and id rather leave it alone than spend $130
Ryan, flush your coolant around 30,000 miles. I waited untill 50k and my heater core clogged!!  :smash:
Crappy dexcool!!  :crazy:
I got a 5yr unlimited alignment package from Tire Kingdom(used to be Mueller Tire locally, but got bought out) for around $150 or so if I recall.  They've done 2 so far and no problems.
Ryan, I got a price FROM MY DEALER to do an FEA for $45.  Thats for the Jimmy, but she said that would be for any truck, that wasn't modified.  That's a regular Pontiac/GMC dealer.  But if you don't need it, your truck is still driving straight down the road, I wouldn't get one.
Just had the coolant changed (49,000 miles).  I didn't have the heat problems that Mervz had, but the flush all but eliminated the "gurgle" sound coming from the vents at low speed/hi rpm's.
Ryan, I paid ~ $70 for an FEA on Green at my dealer - it was a 4x4, done about 3 yrs ago.
I never really bought into the 100,000 mile fluids anyway, so I'll prob. change my coolant, tranny, x-fer case and punkins at 50,000 miles w/ synthetic alternatives (dexcool for the coolant) .  I think it's a good idea to have the tranny professionally flushed too.
If for no other reason, I'd change the coolant sooner to replace the thermostat.
I got another price for an alignment and it was $69.95 (not bad) but their prices for the other things were higher
if that trans service is a flush
AND filter, your getting a GREAT deal.
if just a flush, its still on par with prices, along with the coolant flush
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
