Hello,
I'm not sure how to remove the air filter housing. This isn't just replacing the air filter....this is removing that whole box so that I can access the passenger headlight bulb.
Do I have to remove some screws that I cannot get my hands down to?
Is it something I just yank on(attached by some clips?)?
Usually the bucket or bottom part of the air box is secured in with rubber style grommets. Just gotta tug and it will come up.
Tapatalk via Moto X
Just disconnect the tube to the box, unplug your maf, and give it a couple good tugs. It just presses into 2 rubber grommets. For some reason I always have a hard time snapping it back in though.
I pulled mine out a couple of weeks ago to install silverstar bulbs. I am trying to recall. I think there are a couple of 7mm screws you need to remove. Pull the air tube off. There are two plugs that go into grommets, you just pull up to pop them lose. There is a built in drain tube on the bottom of the air box that slides into a slot in the supporting tray. Once you have the box popped out of the grommets, you will need to wiggle/slide the air box toward the driver's side and it should come up.
  • 6 years later...
Thanks guys. Just read your comments to remove air box. A must if your replacing passenger lamp on a 2015 Silverado.
After removing Inlet hose tug firmly to remove. I installed using a small dab of grease to lubricate grommets and stepped into box. Done.
Quick note the cover that goes over lamps can NOT be 180* off. It will not lock. ?
TonyK
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 2,337 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
