5.3 magnasun anyone?
quickvert1
I think these trannys will be more then ok up to about 600hp
What gets me is the 414hp claim they have on the website... I have seen these trucks be 10hp shy of that with just bolt ons.
I would expect 500hp from a blown 5.3....blower cam and all....
A cam would be nice, just have to save up for that one. I'm pretty sure the truck can handle more but why take the chance that something catastrophic could happen. Besides before I go with more i'm gonna want to upgrade my injectors
  • Replies 127
To be fair magnacharger offers a powertrain warranty lol
I would buy that for sure!! I think Maggie, whipple and procharger offer powertrain warranties
They do offer a warranty, but like everything else they sell its not cheap... Well that also depends on if you have to use it
Yah i know....
I called Hennessy about doing me up one of dem derr HPE500 packages and if they would install a blower cam from Lingenfelter..... They est it at close to 550ish HP but 10K yah..... Wow.... Lol
Yah i know....
There is another guy on here who went with the Hennessy Kit and he said they had his truck for over 2 months.
I would rather do the install my self. I didnt ask whatvthe turnaround time was either!
Did you install yours??
My schedule was so hectic after my last 6 month deployment then my company sent me to Utah for almost 3 months after only being home for 2 weeks. I didn't have the time or space in my garage and I have a friend who builds trucks/cars so I took it to him. He has a Nissan that's putting out over 830HP at the rear wheels so it was an easy decision. 12981d56011dc7636d770aba76087d42.jpgfe2cdc994aef46e759125944ebf4f301.jpg
God that is sick!!!
The install doesnt seem that daunting when you look at what is involved.
question..im sure u lost a couple psi with the longtubes did u just keep the stock pulley or did u get a smaller to get it back up? what r u running now around 5 psi?
I never thought about losing any boost with the headers. I'm running the stock pulley which I'm assuming is still giving me 6 psi (as per Magnuson). Guess that's something I'll have to look into a little further.
God that is sick!!!
The install was done in less than a day the longest part is waiting to get the PCM back after mailing it to Magnuson.
Yikes.... They don't have a hand held? Seems like something essential to get the truck up and running atleast to some set parameters that they pre load.
Idk what kind of dyno my tuner has as he just got it but they didba single cab with a whipple and a 9psi pully and idk what else..... 5.3.... Remember 5.3...... 578HP/586tq to the wheels.
Good god!!! Lol
About boost loss.... Dude its probably half a psi with LTs.... Boost is pretty much backpressure so you add more flow less PSI.... But u might make more power. Only a dyno would be able to answer that.
Good god!!! Lol
They put a 2 day express envelop with the kit to mail out the PCM. Mine was out on Monday and back on Friday.
Do they lock out the PCM? For lets say a tuner to tune it afterwards?
Nope, which made me happy because I had already bought an Auto Cal from Black Bear. I saved the Magnuson tune and am currently running a tune from Black Bear
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 516 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
