5.3 magnasun anyone?
quickvert1
  • Replies 127
My buddy did. Its pretty good, i hope to race him in my 2014 silverado 6.2 when it gets here in a week. I think i can take him.
It might be close, but the torque curve with a Maggie is unreal. Unless he has traction issues I don't see a stock 6.2 out running him. Especially if he pulleys down a bit.
Your beat!!! He puts your flywheel numbers to the wheels almost!!
LOL... not sure what you are expecting out of your 6.2 but good luck. If the tuner for the Maggie is a half assed tuner, you still wont touch it. A well tuned NA 5.3 will probably make you sweat a little.
On another note, from a tuners perspective, I'm not a big fan of the 1900, too limited. Now throw a hairdryer on there and start breaking stuff... thast what I love about trucks, plenty of room under the hood, no bs with relocating fuse boxes like in a Gen1 CTS-V or putting twins where the mufflers go with 500 miles of exhaust piping (major downfall to turbos if room is an issue) Maggies are a drive it an forget it setup though so if you don't like getting your hands dirty, buy a Maggie.
He does spin out of the whole i just hook and go. To me and him the power difference from his and the 6.2 isnt much. Im going to post a vid when we do.
btw awesome vids. have you taken it to the track?
That's impressive if the 14 6.2 can hang with a 14 5.3 truck with a tvs1900 Maggie.
Are they same trucks? Gear ratios? Alot will matter when comparing these because Lingenfelters supercharged 5.3 with 3.08s was not fast. Hook em both up and no way 6.2 should win I mean my truck will fly but no way I would expect to outrun maggie truck.
Most small blowers like that are typical a 80-100hp-ish gain on 5-6 lbs. unfortunately the linear power of a SC makes all that at shift point but it should still be plenty faster than a stock 6.2. Fully tuned 6.2 for E85 now that should be a race.
I was assuming (I know, I should never assume) that we are talking about similar trucks. If your friends is a 4X4 crew cab with 3.08 gears and you are going to have a 6.2 two wheel drive with 3.73s, then that becomes a different story.
All other factors being even (truck, traction, and driver) then a Magnacharged 5.3 beats a stock 6.2 all day long. No doubt the 6.2 has a lot more potential than the 5.3, so it wouldn't take much to out run him. Then again, he can drop down to a pulley size or two and gain another 4-6lbs of boost (another 80-120 rear wheel hp).
The thing to remember about a Maggie is it makes almost instant boost and is to max boost by 3500 rpm, so peak hp is only the beginning. They make a ton of power under the curve. A centrifugal SC like a ProCharger keeps building boost until shift points, making them better for racing but maggies are better for heavy ass trucks that are daily driven or towing.
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 394 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section.  Here’s photos. What do y’all think?  Thanks.  I apologize for hijacking the thread.
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
