Fuel Pump Replacement Advice
I have a 2007 Classic Crew Cab with the 5.3L and 123,000 miles. I drive 16,000 miles annually and take two trips annually over 800 miles each. I am considering a fuel pump replacement even though I have not had any issues with the fuel system.
What do you guys think?
It wouldnt hurt, but why have you chosen the fuel pump in particular as the precautionary replacement? It seems like an arbitrary part to replace.
....why have you chosen the fuel pump in particular as the precautionary replacement? It seems like an arbitrary part to replace.
Unlike alternators and the like, it's not a replacement most would attempt on the side of the road.
I, too, am curious as to typical life expectancy of fuel pumps (though I suspect if a poll were conducted, mileage @ point of failure would vary greatly).
I'd rather replace myself @ home (as a preemptive tactic) as opposed to out of town where it may cost >$2,000 (not including lost time).
I think that OP's 123K mi.s. a bit premature, though.
I got around 165000kms out of my original fuel pump
103K mi.s. That's not very reassuring....
Mine has let me down twice without any prior warning. Once it was a day after a small road trip back near my house and the second time it was at home.
But it is true that its best done at home instead of on the side of the road or in a random shop.
In my experience, a fuel pump's reliability starts to tank after 5 years in service or 125,000 miles of runtime. I personally change them in my fleet of vehicles every 100,000 miles as by then my pressures are a bit lower. I have never, never had a pump failure that left me walking. It's a good idea to change them before 150k at the minimum. DO NOT get a cheap pump. it will last 6 months!!! Either OE, Carter, or Bosch. If you spend less than 200 bucks it's a POS. Do your fuel filter too. Good luck!
Good points. I hear it whistle very infrequently and have not checked pressure. Since I've already done other pm items at 100k, I think I'll change it.
  • 9 months later...
Well I suspect my fuel pump just went (@ 147k mi.s).
I am 400 mi.s from home.
It happened Christmas morning.
Arghhh!
my truck is at 232K miles and is on it's third fuel pump i believe. Last time it started making noise so we replaced it. It definitely would not be a bad idea if you have the extra money to swing it. But i say drive it till you got a reason to replace it.
My fuel gauge is bouncing all over the place as of late, so it may be getting time for fuel pump number 4 haha
I don't know for sure how many miles mine had on it because I bought it with 232,000 miles, but judging by the corrosion on it I'm not so sure it wasn't the original pump. I just have a hard time believing it could last that long...
my pump just went out at just over 200,000 miles. (2000 1500)
I found a off brand pump for about $50 @ am-autoparts with free shipping and a 10 year warranty. I know getting cheap/aftermarket parts isn't a good idea, but the Delco part only had either a 30 day or 1 year warranty.
    needafix
    needafix
  • Who's Online   0 Members, 0 Anonymous, 477 Guests (See full list)
