Check engine light and stabilitrak light on
So I had to run some errands the other day, started my truck up and bam check engine light, stabilitrak light on with no service message or anything. It started shaking pretty bad and I took it to the shop and it had misfired the #4 cylinder and lost compression. Truck does even have 7500 miles on it and they're tearing the motor apart. Anyone else had this happen?
was it wet out? i had this problem and it was because the spark plug wires and coil packs didn't have any dielectric grease in the connections from the factory. water got into a connection and caused misfires.
It had snowed over the weekend, but It hadn't been moved for 4-5 days because I had surgery n couldn't drive lol..they tried everything with it and said that the #4 cylinder still had no compression. It's been a few days since I took it in, so hopefully I get it back this week sometime.
I was skeptic when I took it in that they'd warranty it because that dealer likes to try n fight customers sometimes with service. I bought a 2009 American luxury coach edition there years back with a lift done by a authorized gm shop that wouldn't void the warranty n they tried to fight me then over suspension wear items that wore out on it.
GM will fight on you lifts because that is not the way they sent the truck out. Suspension issues on trucks with lifts are covered under the lift companies warranty (if they have/offer one).
The service dept at the dealership where I bought the truck tried to fight it until they were notified it was purchased there. I called today about my 14' and the lifter failed on the motor, should have it back tomorrow or Wednesday but I'm def gonna pay close attention, pathetic that you buy a 45,000 dollar vehicle n it s$it's itself before the first oil change.
  • 2 years later...
Hate to dredge up an old thread but I just had this exact issue in cylinder 1. Post is more for research and awareness.
2015 Silverado lt crew. 5.3. 29500 kms
  • 1 year later...
Looks like this is a pretty common thing with these 5.3 V8 trucks. Mine did this exact same thing just lastnight. I just bought the truck a month ago with only 36k miles. 2014 LT. Luckily I have a back up vehicle to drive cause it sounds like dog crap! It threw code PO300 which is a misfire of course. But I've been reading that most common cylinder is the 7 with a stuck lifter. Hopefully its covered under the powertrain warranty the truck still has and I'm not out of pocket!!!! Not very happy at all!!
2018 gmc 1500 max trailer package 6.0 L.  4800 kms.  engine light, stab light, oil pressure spiked and rattled like there were two cummins riding in the box.  engine light flashing.  taking to dealer tomorrow.  not impressed.  shifts like crap too.  always clunking and bucking.  they say is has to "learn".  So far its a slow learner.  Ran gm's for 25yrs.  probably 30 trucks. never had an issue with any of them.  Hope this isn't a sign of things to come...??
Let's wait and see what the dealer says.
Had this happen while on vacation driving through the Rockies. Thought I fried the tranny as I was hauling balls to get to our campsite before dark. Turns out it was just a plug wire that had come loose. :dunno:
Hope you get good news like that!
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
