6.2 stoplight drags
bloudie
3] MAX TOW PACKAGE is the way to get the lower 3.73 rear. it comes with better radiator, extended mirrors, bigger ring and pinion, nice looking 20" wheels, trailer brake controller, frame hitch, 4 and 7 pin trailer light plugs, better springs and shocks. all for under a $1000 on the ltz. if you add something called timbrens to the rear axle you will sit like a dually when you add the tongue weight of a serious trailer, a ride like a caddy when your not towing [$200]
Extended mirrors are not included in NHT Max Tow, but max tow is required if you want to order tow mirrors.
NHT Max Trailering Package, includes 9.76" rear axle, (GT4) 3.73 rear axle ratio, (JL1) trailer brake controller, enhanced cooling radiator, revised shock tuning for increased control, heavier duty rear springs and increased RGAWR
DPN Mirrors, outside heated power-adjustable vertical camper, manual-folding and extending, black. Includes integrated turn signal indicators consisting of 50 square inch flat mirror surface positioned over a 20 square inch convex mirror surface with a common head and lower convex spotter glass (convex glass is not heated and not power adjustable)
1 - Includes (DD8) auto-dimming inside rearview mirror. Requires (NHT) Max Trailering Package.
2 - Requires (NHT) Max Trailering Package.
Note 1 refers to SLE
Note 2 refers to SLT
Plenty of dmaxs in the tens...many into 9's as well...
RCLB lbz/lmm with a tune and supporting mods will hit 12's with under 2.00 60' times no problem
I think 'bloudie' is referring to stock trucks.
so long
j-ten-ner
I bet a dodge RCSB would beat a 6.2 chev...crew can vs crew cab 4x4 6.2 all day
I agree with this. A friend of mine picked up a crew 4x4 ram hemi the same week I picked up my crew 4x4 6.2. We have lined up a few times, the 6.2 wins every time. But its not as much of an ass kicking as every one thinks it should be. Both trucks are ccsb 4x4 completely stock. I have no dout that lined up with a light weight rcsb hemi my money would be on the ram. I love my gmc and definitely wouldnt trade it for the ram, just telling my experience with the 6.2 vs hemi.
    • Would you supercharge the 6.2L on a 2021 GMC Yukon Denali XL with ProCharger?.... 605HP is the stated number without going crazy - it's not the LT4 682HP package, but I'm tempted to install it... This vehicle was ... not... recalled on the engine swap - but I don't really know if that means ...don't do it... or do it;)    Maybe i should start a prediction market pool on it in case it blows up;)   Any thoughts appreciated - I already OWN the supercharger - stopped the installation when the recall was announced and now it's taking up space in storage until I can solve an electrical issue with the vehicle...  4th GMC suburban-equivalent truck - I like them a lot - when they don't a) discharge their batteries randomly, or b) throw a rod at highway speeds;)
    • We tested the sleep mode with an ammeter in series with the negative battery terminal - 30amp fused - so we do know the actual shutdown and non-shutdown current draws and timing of the shutdown sequence.  We just have no protocol information to determine what module is issuing the network keep alive.
    • TrueBlue...Even if you don't have that info stuff displayed, If Mr. Computer thinks there's something you should know about, it will pop up a warning message no matter what else is being displayed. I keep the speedometer displayed all the time, yet the brake pad message pops up anyway.
    • BTW, the 11.5amp draw is all the usual systems active - it's not a single draw - that's the "we're all awake" state of the vehicle - forinstance if the power steps are actuated, the draw will spike to 22amps for that operation.  when the battery is disconnected and then reconnected, the vehicle shuts down that one time only - and we see a 10-15minute progression down 11.5  10.5  9. 8 6. 5. 1.6... 500ma... and then off to sleep at 40 milliamp... as expected.  So we know it's a module that is simply refusing to allow the SDGM to proceed to the sleep state.  We do NOT think it is the telematics VIM module - since we already duplicated the problem with the "VIM bypass" solution installed (we reverted that since it also disables the gmc app - but it does not appear that the telematics system is the culprit).  We've replaced the rear heater control module, tested without the wireless charger, and the other modules on CAN Bus 5 - but still something is keeping us awake and removing X2 from SDGM allows sleep to proceed.  We cannot diagnose from OBD since OBD drops off at about the 9volt level in sleep mode and we can't communicate with the vehicle - also we can't trace the SDGM internal packets from the OBD side - we have Autel Ultra.   Any ideas on why disconnecting X2 would allow sleep to proceed appreciated.  This is no longer a repair situation - this vehicie is simply unusable in this condition and NOBODY at GMC Dealer can even understand what it is doing.  This is crazy.  We made these systems too complex and now we're paying the price.
    • Did this ever get solved?   I'm chasing 2021 Yukon Denali electrical issues - vehicle will not enter sleep mode - we can disconnect and reconnect the battery and it will sleep - but that's likely because we powered down whatever module doesn't correctly sleep.  once we start/accessory the vehicle and turn off, it will stay at 11.5 amp draw with something keeping the SDGM alive - it appears to be activity on the X2 segment, specifically CAN FD Bus 5 - but we don't know which device and we think we've already isolated all of the devices on that segment - so what keeps the BCM and/or the SDGM alive is unknown.   I don't yet have a packet trace from CAN 5 (and since this Global B we might not get much info from it) - but the vehicle has been down for 8 weeks and previously GMC Dealer was unable to resolve "kills battery" issues with this particular vehicle - so I'm at a loss - it seems to be beyond local repair capabilities - and the number of "telematics keeps vehicle from sleeping" posts indicates this whole architecture has major issues - I hate to say it, but we might have to install a battery cutoff switch on the front grill - one of those red boat switches - to turn off the vehicle.;)  Any pointers appreciated;)  I just bought a CAN FD interface and I'm planning to try Savvycan and Peak Can SW to triage this further.
