I'm curious about this because I've looked it up and have gotten mixed answers, second reason I found a chevy silverado 1500 1999 and the ad says it has 3 doors... This is at a dealer as well
Thanks
Wikipedia also says 3-door for the first year. No firsthand experience though.
Right around Jan/Feb of 2000 is when they started with the 4-door ext. cabs......so early build 2000's,and all '99's are 3-doors,as well as any of the older GMT400 trucks are 3-doors also.
Edited by MS3DALE
Hmm we'll tbat sucks. I found a nice 99 but it's the 3 door and it seems like only getting on on passenger side would get old quick
Jan-March of 2000. I ordered my truck in February as a 4 door ext cab and it was built in March.
Didn't realize they were the last to add the fourth door. I remember as a kid having to get into extended cabs without the doors, how things have changed. Haha
Only downfall of the ext cab with the 3/4 doors, is the rears are suicide doors, so getting in/out of the back in tight spots is a little tricky. Other than that, works slick.
I have 3 doors and would not like this config again. Search more and get 4 doors for way better access and passenger comfort. The person behind the driver is locked in and I don't wish that upon anyone.
Edited by white1500
I had a '99 with 3 doors, always wished it had the 4th door.I have a 4 door 2008 extended cab now. I like the suicide door configuration, helps if you want to get something large in the back seat area. And the NNBS doors open all the way flat.
Edited by TooTall1
I had a 1997 Silverado that did not have any third door. I think maybe the early run ones didn't have option?. I just googled the 97 just to make sure because I just couldn't remember . Sure enough the pictures don't lie. I worked with a guy that had a truck just like mine but his was a 1998 1/2 . This half year model is when the Silverado started as the name of the model not a trim level. His tailgate didn't have the large chrome band across it, just Silverado at bottom corner. I sure miss that 1997 truck. If I could put that body on my 07 (nnbs) ,with four doors of course I would be happy. The size of these trucks have gotten out of hand.
While at the Chicago auto show I looked at the new Colorado/ Canyon and the crewcab-longbed was pretty close to size of my old 97. By the way that new Canyon is sharp looking .
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
